Usb Connectors types & Their names. Usb wires. Usb cable types and their port names:
Usb-A: Oldest computer cable’s male and female, rectangular in shape.
Versions: USB 1.1, USB 2.0, USB 3.0 (blue color), USB 3.1, USB 3.2.
USB Type-A 3.1/3.2: Similar to USB-A but with additional pins for faster data transfer. High-speed devices and modern computers. Often blue to distinguish from USB 2.0.
Usb-B: the other end of usb cable which used to be inserted into printer’s back side. Square shaped with beveled corners. V2.0, 3.0 (blue)
USB Type-B 3.1/3.2: A larger, square-shaped connector with extra pins for USB 3.1/3.2 speeds.
Mini-Usb: That which was nokia’s charging connector (male side). A smaller, trapezoidal connector. Ver 2.0.
Micro Usb: A compact, flat connector. Used for mobile charging even till now, just before c type. Ver 2.0, USB 3.0 (wider connector with extra pins).
Pins 1 (rightmost pin when the port is looking towards me with its taper side down/towards earth and pins looking upwards) to 5 (5th is outer patti): Pin1: Vcc/VBus: 5v+, Pin2: Data-, Pin3: Data+, Pin4: ID (identifies the device as a host or guest). Pin5/patti: Ground.
USB 3.0 Micro-B: A wider version of Micro-USB with extra pins for USB 3.0 speeds. Used with (even mine) External hard drives and high-speed devices. Versions: USB 3.0.
Pins: first 5 pins are same as Micro Usb2.0. 6th Pin: sstx- (superspeed transmit negative). Pin7: SSTX+ (super speed transmit positive). Pin8: Ground for shileding & noise reduction. Pin9: Super Speed Receive Negative. Pin10: Super Speed Positive.
Usb-C: A small, oval-shaped, reversible connector. Now widely prevalent, even charges my own mobile. USB 3.1, USB 3.2, USB4, Thunderbolt 3/4. Supports faster data transfer, higher power delivery, and alternate modes (e.g., DisplayPort, HDMI).
Lightning (Apple Proprietary): A small, reversible connector developed by Apple. Not a USB standard but often used with USB-A or USB-C cables (on the other end).
